primo74620 Posted August 29, 2011 Report Share Posted August 29, 2011 Found a Weber 32/34 for my 74 620 and I want to know how this would work on my truck??? Quote Link to comment
lil89ram50 Posted August 29, 2011 Report Share Posted August 29, 2011 it would work great if its in good condition. rebuid kits are cheap if you are unsure and super easy to rebuild Quote Link to comment
primo74620 Posted August 29, 2011 Author Report Share Posted August 29, 2011 it would work great if its in good condition. rebuid kits are cheap if you are unsure and super easy to rebuild Thanks, the carb looks like it was already rebuilt. I am just going to keep it till the Hitachi goes out or starts giving me trouble. Quote Link to comment
banzai510(hainz) Posted August 29, 2011 Report Share Posted August 29, 2011 did it come with a carb adapter? the bolt spaceing is different on webers Quote Link to comment
datsunaholic Posted August 29, 2011 Report Share Posted August 29, 2011 If it's a 32/34 DFT they have the same bolt spacing as a stock Hitachi. At one time the DFT was a smog-legal replacement, since they had an adapter for the stock air cleaner and many had C.A.R.B. certification tags. Quote Link to comment
banzai510(hainz) Posted August 29, 2011 Report Share Posted August 29, 2011 If it's a 32/34 DFT they have the same bolt spacing as a stock Hitachi I did not know that Quote Link to comment
datsunaholic Posted August 29, 2011 Report Share Posted August 29, 2011 I have a couple DFTs. Totally different carb than a DGV/DFV type. Also really obsolete- parts aren't easy to come by, except jets which are common to many different Webers. They seem to run OK but they have to be mounted backwards (choke in FRONT) to make the throttle work. Quote Link to comment
racerx Posted August 30, 2011 Report Share Posted August 30, 2011 You can also call weber direct and ask about their adapter plate and you may have to modify linkage..good luck. If that carb is been sitting for awhile, you may want to freshen it up some or rebuilt...you don't want to go through the hassle of installing and then it squirts gas all over the place. Good luck.. Quote Link to comment
