dspeirn Posted August 25, 2011 Report Share Posted August 25, 2011 so i finallly got my car running but i still need to work out some kinks. I start the engine and it runs fine i rev it up and it advances and sounds good. problem is when i put it in gear and let the clutch out it falls on its face, it doesn't totally die but almost and then i can get it to come back up but then it still barely has any power. i shot it with the timing light, but i don't know what marks to line up for the correct advance. any help would be appreciated. im pretty sure its a timing and or mixture thing. Quote Link to comment
jefe de jefes Posted August 25, 2011 Report Share Posted August 25, 2011 http://www.olddatsuns.com/620tech2.htm#TM http://www.redlineweber.com/html/Tech/carburetor_set_up_and_lean_best_.htm Quote Link to comment
banzai510(hainz) Posted August 25, 2011 Report Share Posted August 25, 2011 has this run before? or was the oil pump changed/front cover and its off tooth on distributor olddatsuns.com Quote Link to comment
dspeirn Posted August 25, 2011 Author Report Share Posted August 25, 2011 yeah i drove with it in someone elses car, pulled it, it sat for about a year, then startred right up. i got all new plugs and wires by the way and good compression on all cylinders. also as a sidenot i have dual mikuni 44s. Quote Link to comment
