Just Joel Posted August 17, 2011 Report Share Posted August 17, 2011 Anyone have experience with this clutch/brand or any recommendations otherwise? Thanks Joel Quote Link to comment
motavated Posted August 17, 2011 Report Share Posted August 17, 2011 exedy clutch? Ohhh well that is about the best damn clutch you can put on your datsun i tell you what. Quote Link to comment
ggzilla Posted August 17, 2011 Report Share Posted August 17, 2011 Yes, Except for Nissan genuine parts, Exedy is a good brand. A lot cheaper too. Quote Link to comment
motavated Posted August 17, 2011 Report Share Posted August 17, 2011 Check this shit out. http://www.exedyusa.com/oe/Clutch_Specifications There is also a stage II Quote Link to comment
Just Joel Posted August 17, 2011 Author Report Share Posted August 17, 2011 Alright, alright... sorry for the dumb question. I'm just not up on brand names. No pic on the link you posted but I assume it’s the stage one option? With my mild l20b, is anything more than stock clamping force required? Thanks Joel Quote Link to comment
banzai510(hainz) Posted August 17, 2011 Report Share Posted August 17, 2011 Exedy/Daiken stage 1 in that size also. also "SPEC" Brand which I got throw importrp.com Joel the one you listed is a stock clutch and is fine if cost is a issue. as the trucks I beliece are 550KG anyways or was is 450KG as you listed a 225mm flywheel. Quote Link to comment
SR20-620 Posted August 17, 2011 Report Share Posted August 17, 2011 exedy clutches rule!!! if you put an oem exedy clutch side by side with a sachs, dynapak, perfection etc. you will realize the quality of the exedy is above and beyond the rest. Im nto saying there is anythign wrong with the other clutches but for the money their quality is awesome!!! Quote Link to comment
