73DATSON Posted August 15, 2011 Report Share Posted August 15, 2011 Can you install a airfuel meter and a02sensor? To work on a 510? I know it needs to be hook up to a ECU but that's if you have fuel injection? Quote Link to comment
DISLEXICDIME Posted August 15, 2011 Report Share Posted August 15, 2011 Can you install a airfuel meter and a02sensor? To work on a 510? I know it needs to be hook up to a ECU but that's if you have fuel injection? yes and you dont nead a ecu just the gauge and a sensor do your self a favor and buy a wide band not a narrow band. did you buy one yet ? if so what did you get Quote Link to comment
Sealik Posted August 15, 2011 Report Share Posted August 15, 2011 Innovate makes some good wide band A/F ratio gauges. Have 1 in my LZ 720...and another cheaper brand on my EFI 720 Quote Link to comment
73DATSON Posted August 16, 2011 Author Report Share Posted August 16, 2011 yes and you dont nead a ecu just the gauge and a sensor do your self a favor and buy a wide band not a narrow band. did you buy one yet ? if so what did you get i just have the gauges for now. i found a bosch wideband. i might pickup? Quote Link to comment
73DATSON Posted August 16, 2011 Author Report Share Posted August 16, 2011 Innovate makes some good wide band A/F ratio gauges. Have 1 in my LZ 720...and another cheaper brand on my EFI 720 is that 720 carb? Quote Link to comment
Sealik Posted August 16, 2011 Report Share Posted August 16, 2011 is that 720 carb? That 720...is a 84 4x4...with an LZ23...Weber 38/38 Quote Link to comment
Sealik Posted August 16, 2011 Report Share Posted August 16, 2011 This is the one I got....... http://www.ebay.ca/sch/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=%09+Innovate+MTX-L+Air%2FFuel+A%2FF+Ratio+Gauge+Kit+3ft+3845&_sacat=See-All-Categories Quote Link to comment
ggzilla Posted August 18, 2011 Report Share Posted August 18, 2011 Yes, this will work on carbureted engines. The only problem is the sensor will soon foul because the mixture is off. Maybe widebands are better, but in the past, you used it for testing, then removed the sensor for regular driving so that it wouldn't be ruined. Quote Link to comment
73DATSON Posted August 18, 2011 Author Report Share Posted August 18, 2011 That 720...is a 84 4x4...with an LZ23...Weber 38/38 how long u had it in your car? any problems? Quote Link to comment
73DATSON Posted August 18, 2011 Author Report Share Posted August 18, 2011 Yes, this will work on carbureted engines. The only problem is the sensor will soon foul because the mixture is off. Maybe widebands are better, but in the past, you used it for testing, then removed the sensor for regular driving so that it wouldn't be ruined. Kool,good to know. i'm ordering a wideband(bosch). hope it last. Quote Link to comment
Sealik Posted August 18, 2011 Report Share Posted August 18, 2011 Yes, this will work on carbureted engines. The only problem is the sensor will soon foul because the mixture is off. Maybe widebands are better, but in the past, you used it for testing, then removed the sensor for regular driving so that it wouldn't be ruined. Whos mixture? how long u had it in your car? any problems? Had it in the truck about 2000kms....no problems.....and still testing/diagnosing the engine.... :D Quote Link to comment
flyfish Posted June 23, 2013 Report Share Posted June 23, 2013 Has anyone found a USB to DB-9 connector for these Innovate kits? Quote Link to comment
Just Joel Posted June 24, 2013 Report Share Posted June 24, 2013 This? http://m.radioshack.com/radioshack/product/detail.do?itemId=2292430&op=%22http://www.radioshack.com/product/index.jsp?productId=2292430%22 Quote Link to comment
flyfish Posted June 24, 2013 Report Share Posted June 24, 2013 Thanx. All I need now is to run Windows (ech) on my Mac... Unless someone knows of Mac compatible software to use with the Innovate hardware. Quote Link to comment
mantas Posted June 30, 2013 Report Share Posted June 30, 2013 Get parralels for MAC and you can run windows. As for the wideband, get the LC-1 from Innovate. Its great because if the sensor every fails you can pick up a new one out of a Jetta from Autozone. Do not get an AEM no matter what, they are inaccurate. Quote Link to comment
flyfish Posted July 1, 2013 Report Share Posted July 1, 2013 Thanks. I was really hoping for something that ran on the OSX platform.. Bootcamp then Parallels were my next choices. I did pick up the Innovate LC-1 with a G2 gauge... Quote Link to comment
