d510addict Posted August 15, 2011 Report Share Posted August 15, 2011 So the shop that did my exhaust made it very tight on the l16 somehow, and now it is not really fitting the l20b properly. For starters I had to loosen the bolts holding the mani to the collector so the mani would fit onto the head studs, also the pipe just down from the collector is up tight against the transmission and knocking against it while driving. I have a flange that mklotz made and was going to use that as a spacer between the mani and the collector to get the exhaust pipe off the transmission, but I do not believe that will fix the problem of the mani not fitting properly. Is there a way relax the exhaust so the mani will fit on? Or am I going to have to pay the exhaust shop to make a collector so that I get proper fitment? Quote Link to comment
H5WAGON Posted August 15, 2011 Report Share Posted August 15, 2011 My Y pipe has the custom by dent mod.....to clear the engine, trans... :huh: Time to get that custom Y-pipe done. :P Quote Link to comment
mklotz70 Posted August 15, 2011 Report Share Posted August 15, 2011 the L20 block is about 3/4" taller....which raises the exhaust mani with it....so if it was tight on the L16, it probably won't clear the L20. Possibly pie cut the outside of the tubes so it can swing out a bit...then reweld. Easier to say with pics....just guessing otherwise. Quote Link to comment
d510addict Posted August 15, 2011 Author Report Share Posted August 15, 2011 I'll try and take pics tomorrow. Quote Link to comment
