Wanting To Replace U-joints
Zeusimo
  • Replies 4
Mark the drive shaft and each flange so that when the new U joint is in they go back in the same relation to each other.
You will need three for the 620.
U joint replacement
The rear tranny seal can easily be replaced while the drive shaft is out.The Nissan part number is #32136 U0100 and is used in all 620 4 and 5 speeds after '73, 280z and zx non turbo, 720, S110 and even fits the 200sx dogleg. Very common seal and will also fit the 521/510 610/710 A10 I believe. About $8 at dealer cross referanc it at NAPA for about $5. Pry the old one out with a screwdriver, cover new one with block of wood over it and use hammer to drive it in. Using wooden dowel carefully tap it in fully. Grease the rubber lip before installing it.
