ryknot Posted July 25, 2011 Report Share Posted July 25, 2011 Im in the middle of a 5speed swap in my 620 - I gots all my parts except for the plate that sits between the engine and tranny such as this . . I dont need something all polished up and pretty, just needs to be useable - anybody gots one?? Ill buy it or I have some 620 parts Id trade. . . maybe I have what you need? Link to comment
ggzilla Posted July 25, 2011 Report Share Posted July 25, 2011 Not all engine/transmission/flywheel combinations used an engine plate. Are you sure you need one? It affects the release bearing carrier length. The later cars used them to reduce NVH. Link to comment
ryknot Posted July 25, 2011 Author Report Share Posted July 25, 2011 Well I guess I aint sure . .? It just seemed strange that the bottom 3in or so of the flywheel would be exposed to the elements, so I figured I must be missin this part - No? It is a 78 or so 280z 5speed thats going in a 75 620 with the original engine. What do you guys think/know? And what does NVH stand for? Link to comment
Abe Froman Posted July 25, 2011 Report Share Posted July 25, 2011 I am sure I have a spare one of these, PM if you have not located one yet. Link to comment
datzenmike Posted July 25, 2011 Report Share Posted July 25, 2011 Not all engine/transmission/flywheel combinations used an engine plate. Are you sure you need one? It affects the release bearing carrier length. The later cars used them to reduce NVH. I haven't seen an L without the plate to cover the front of the transmission. You could use one from an automatic. It's two piece but does the same job. Link to comment
ggzilla Posted July 25, 2011 Report Share Posted July 25, 2011 Yes, the front of the transmission is always covered. Some L-series manual transmissions used a 1/2 plate (dust cover) that bolted on after you mate the engine & transmission. Maybe only the early ones? Link to comment
nismo dr Posted July 25, 2011 Report Share Posted July 25, 2011 And what does NVH stand for? NVH = Nissan speak for noise, vibration, & harshness Link to comment
Guest kamakazi620 Posted July 26, 2011 Report Share Posted July 26, 2011 NVH = Nissan speak for noise, vibration, & harshness Or basically Nismo DR has a PHD in NVH Link to comment
H5WAGON Posted July 26, 2011 Report Share Posted July 26, 2011 That one is not fun to pull at the wrecking yard...:P Have one on my back porch...collecting dust. Link to comment
ryknot Posted July 26, 2011 Author Report Share Posted July 26, 2011 Awesome info! Thanks for your help guys - so appreciated. :) Link to comment
