nismo dr Posted July 12, 2011 Report Share Posted July 12, 2011 In the process of doing the disk brake swap on my 521, got it together, went to bleed it and fluid is dumping on the floor from the master, took it apart and found: I need a cheap ass 79-81 280zx master, broken core is fine, I just need to get one of those seals out of it, there are four I think so chance are there would be a salvageable one even in a scrap master. local preferably, this is my daily driver and its out of commission till I get this handled Link to comment
H5WAGON Posted July 12, 2011 Report Share Posted July 12, 2011 If its the 7/8 bore master....I have a core, the seals are dry but might work. The trick is to get them off. I will put some brake fluid on them and see if the come off Link to comment
nismo dr Posted July 12, 2011 Author Report Share Posted July 12, 2011 yeah, its a 7/8". let me know if they survive! thanks Link to comment
yello620 Posted July 13, 2011 Report Share Posted July 13, 2011 280zx should be 15/16" Link to comment
datzenmike Posted July 13, 2011 Report Share Posted July 13, 2011 Yes they are. Had to build one myself. And you should get a kit and do it right. Used brake components....... no. It'll just leak again. Link to comment
nismo dr Posted July 13, 2011 Author Report Share Posted July 13, 2011 no jobbers I work with (have credit with) have kits, I'm tapped out on this swap and have no brakes, so used is my only option right now Link to comment
datzenmike Posted July 13, 2011 Report Share Posted July 13, 2011 I hear ya. I had the same problem went to Nissan and they sent me a rebuild kit for a clutch, the idiots. "No problem, we'll just return it and get the right one.... Oh... NLA" Went to NAPA and they said they were not made any more but the counter guy was real helpful and had 'other' sources. Called this guy up and had a kit the next day. When I picked it up the guy there said he'd been working there over 20 years and had never seen that make in that type of box color and artwork. Said that kit must have been sitting on a shelf for a long time. The old zx seals had horizontal score lines on them from sliding back and forth in the cylinder. I wonder if these could be lightly 'sanded' down to make a better seal? If you ever find a supply of 15/16" seals let me know. Link to comment
SR20DETdatsun510 Posted April 26, 2012 Report Share Posted April 26, 2012 I need a 15/16" rebuild kit now. What eve came of this?? I searched and searched and although allot of people said they got a kit, they never replied back to yhe thread to tell ifit worked or not.... =( Link to comment
