Topher88 Posted July 7, 2011 Report Share Posted July 7, 2011 So in my 510 i have an L20B and the throttle cable is simply sitting in the groove in the pedal with nothing preventing it from popping out. There is a ball at the end of the cable along with a white plastic thing that looks cracked. i saw some pics of other cables and it all looked like stuff thats already on the cable and that you can not add to it. any help would be greatly appreciated. Quote Link to comment
Stupid_fast Posted July 7, 2011 Report Share Posted July 7, 2011 Can you get a picture of it? This is how I mounted my lokar but it sounds like you have a different end. Quote Link to comment
FiveTenzo Posted July 7, 2011 Report Share Posted July 7, 2011 is the peddle moddified? looks someting similiar to what is needed to do for a ka24de swap. Quote Link to comment
Unclejesse88 Posted July 8, 2011 Report Share Posted July 8, 2011 The white plastic thing is what holds the cable in place. It should go into the hole in the pedal and stay there, basically closing the end of that hole/slot in the pedal to where the cable can't come out. The cable should move freely in the white plastic thing Quote Link to comment
Topher88 Posted July 8, 2011 Author Report Share Posted July 8, 2011 ya... that thing is cracked and dosnt go in the hole..... Quote Link to comment
hang_510 Posted July 8, 2011 Report Share Posted July 8, 2011 thats not the stock linkage. is the cable coming out of the notch? maybe you could squeeze it closed with the cable in position? Quote Link to comment
Stupid_fast Posted July 8, 2011 Report Share Posted July 8, 2011 I was thinking you could use a ~4mm(?) bolt/nut + washers in the notch so the cable cant slip out? Would it work? Quote Link to comment
hang_510 Posted July 8, 2011 Report Share Posted July 8, 2011 I was thinking you could use a ~4mm(?) bolt/nut + washers in the notch so the cable cant slip out? maybe if it wasnt perpendicular... my pedal is similiar and i used a stud? ( :blink: it has 5 holes along the length) to attach the lokar cable in a similiar method Quote Link to comment
Stupid_fast Posted July 9, 2011 Report Share Posted July 9, 2011 maybe if it wasnt perpendicular... my pedal is similiar and i used a stud? ( :blink: it has 5 holes along the length) to attach the lokar cable in a similiar method Hmm, the top of yours is rotated 90 degrees from what mine is. How is the cable slipping out? Isn't it coming out the top notch? If so, cant you block up that notch with something? That's what I mean't with the bolt. Quote Link to comment
HRH Posted July 9, 2011 Report Share Posted July 9, 2011 You just need to replace the plastic bushing. The back of it that sits in the round hole on your throttle cable has broken off. Get a new one from Nissan, or go to the wrecking yard and find a random Japanese vehicle from the 70's or 80s with a good plastic insulator and grab that off. Install on yours and good to go! I used an '87 B2000 Mazda throttle cable on my 510. Very similar setup. Quote Link to comment
