JCR Posted July 4, 2011 Report Share Posted July 4, 2011 OK OK I did the search thing and all i could get was that the thread for the block (1/8 BSP) what i am trying to do is add the triple gauge cluster and the volt and block temp no problem.... but the oil pressure is mechanical can i get a 3 way spliter and thread into the block and hook the oem sender to one side and the mechanical to the other side ? if so how ? and what would i need ??? as always thank you all Quote Link to comment
Wide14u Posted July 4, 2011 Report Share Posted July 4, 2011 yes its a brass t fitting Quote Link to comment
dirtydiesel Posted July 4, 2011 Report Share Posted July 4, 2011 yes you can do that i do it all the time on diesel engines for boats. just get your self a (brass or stainless) nipple/ run tee/ pipe thread sealer(or tape) i find it best to thread the close nipple into the run tee before threding into the block. be sure to have the thread sealant on before you thread it in. run the threads in snugg. and position the tee where you can easily thread in the two senders. and ta dah. Quote Link to comment
JCR Posted July 4, 2011 Author Report Share Posted July 4, 2011 ok so home depot lowes etc is the 1/8 BSP a common size or even the right size ? Quote Link to comment
ggzilla Posted July 4, 2011 Report Share Posted July 4, 2011 Bolting the sensor or hard line into the T-connector is not recommend, because occasionally they break. Use a braided hose from the oil sender hole out to the bodywork, and then mount the tee with senders and lines in place. The oil pressure switch threads is 1/8 BSPT (british standard pipe tapered), not SAE, not metric. Quote Link to comment
JCR Posted July 5, 2011 Author Report Share Posted July 5, 2011 working on wiring the lights for the gauges and the oil sensor still but mounted the cluster mounted a plate to the same place as the ashtray and attached the cluster to the plate larger images on last page of cardomain link Quote Link to comment
JCR Posted July 16, 2011 Author Report Share Posted July 16, 2011 dosent want to start burping white smoke when turned over oil in the carb wants to backfire still wont run but will turn over WTF? Quote Link to comment
datzenmike Posted July 16, 2011 Report Share Posted July 16, 2011 Plug wires mixed up. Quote Link to comment
ggzilla Posted July 17, 2011 Report Share Posted July 17, 2011 yep, plugs wire out of order (burping white smoke when turned over , backfires) Quote Link to comment
JCR Posted July 18, 2011 Author Report Share Posted July 18, 2011 i'll give it a shot but dont understand how that could have happened maybe the distrubuter cap is 180 degrees off thank you everyone Quote Link to comment
JCR Posted July 18, 2011 Author Report Share Posted July 18, 2011 duh!!!!!! cleaned moter the other day ......water in the distributor started up just fine today i feel dumb Quote Link to comment
