d510addict Posted July 3, 2011 Report Share Posted July 3, 2011 I am gather material for making door panels for my 521 but I'm not quite sure what clips to use to attach the panel to the door, anyone have suggestions? Quote Link to comment
DatWifey Posted July 4, 2011 Report Share Posted July 4, 2011 This is what the stock clips look like. At least they are in our '71 521. Also, not sure if you have the cups in the door for them to clip into. If not, these are them. You can also order them off of nissanparts.cc, if you can find them through their shitty search. We found them once, but I can't seem to find them again right now. Quote Link to comment
d510addict Posted July 4, 2011 Author Report Share Posted July 4, 2011 good to know thank you!!! Quote Link to comment
DatWifey Posted July 4, 2011 Report Share Posted July 4, 2011 You're very welcome :) Quote Link to comment
MikeRL411 Posted July 5, 2011 Report Share Posted July 5, 2011 This is what the stock clips look like. At least they are in our '71 521. Also, not sure if you have the cups in the door for them to clip into. If not, these are them. You can also order them off of nissanparts.cc, if you can find them through their shitty search. We found them once, but I can't seem to find them again right now. Toyota uses a similar clip but with a sound deadening foam pad. Holds tighter and is quieter. If you can sneak into a Toyota dealership without being seen by the Ratsun secret police you might try to get some. Quote Link to comment
