Stupid_fast Posted July 2, 2011 Report Share Posted July 2, 2011 Hey all, I just finished installing a throttle cable, ect to my 32/36(car still is not running.) and whenever I open the throttle usually when it closes back it squeaks. Is there a common cause of this? I tried loosening up the bolt, that didnt help. It happens when the first throttle is opening/closing, the second one does not squeak. Should I just spray some grease/lubricant on it? pic, Also, the throttle will not go back to fully closed with just the original spring, I have since added a second spring to pull it back shut and works fine, is that an OK setup? For the pedal, its really stiff to push down. What type of lubricant to use on where the throttle connects to the plastic piece that screws into the firewall? After some searching I was thinking white lithium grease? Thanks. Quote Link to comment
datzenmike Posted July 2, 2011 Report Share Posted July 2, 2011 Extra springs will just load the throttle shaft down and wear an oval hole in the carb body. This will throw the throttle plate out of alignment and it won't close properly. You'll have fast idle on throttle return that has to be released by tapping the gas peddle, very annoying. The worn body will also leak vacuum throwing the idle mixture off. Quote Link to comment
Stupid_fast Posted July 2, 2011 Author Report Share Posted July 2, 2011 Extra springs will just load the throttle shaft down and wear an oval hole in the carb body. This will throw the throttle plate out of alignment and it won't close properly. You'll have fast idle on throttle return that has to be released by tapping the gas peddle, very annoying. The worn body will also leak vacuum throwing the idle mixture off. OK- so how do I get the throttle to close fully with just the original spring? it does not have enough force to close itself connected to the throttle cable/pedal. Suggestions? Thanks. Quote Link to comment
banzai510(hainz) Posted July 2, 2011 Report Share Posted July 2, 2011 the carb has its own speing then you have to add a sping yourself. really theyr should have been one on the stock hitachi set up. Usually its a spft spring just enough to close the carb. But not a hug ones wear it wear out your foot and throttle shaft. I go to home depot and make a plate to the valve cover bolt near by . look stock and clean Quote Link to comment
