naps-z motor wiring issues
  • Replies 9
Ill have some up tomarrow I think it could of been from his optima battery with 30 year old wiring I'm really lost at this point
its not b/c of your battery. you have some sort of wrong connection or short ect somewhere
If you have a '73 can I assume you have swapped a NAPS Z motor into it? Are you using the NAPS alternator or the '73? If using the NAPS you will have problems. Otherwise everything should wire up and run just fine.
