lowering options
baycity720
  • Replies 7
Turn the torsion bars on the front down and/or re index them and add a 2", 3" block in the rear between the axle and the leaf springs.
If you plan to mod this truck you should start a build thread so all questions and answers are in the same place. It's easier to find and keep track of.
What is the best way to do a performance lower a 720 without fabrication?
Parts? Just a kit with lowering blocks. The blocks have a nub on one side to lock into the spring perch on the bottom of a 2wd axle. The other side has a hole for the nub on the leaf spring pack. Slip the block between the axle and the leaf springs and tighten down the longer U bolts. This one is 2" More will likely change the pinion to drive shaft angle too much and it will vibrate.
Turning the front torsion bars down will also throw the camber and toe out as well. A small amount you can live with but the more you lower the more it will be out.
you can locate your torsion bar adjustment by crawling under your truck and following the straight round bar from your front lower control arm back to the rear of your transmission crossmember, you will see a bolt going upward. loosen the jam nut a bunch, then loosen the other nut bellow it.... make small adjustments at a time (like 3 turns max) then roll the truck forward and backward letting the suspension relax, if you dont, your tire's grip will cause you to have a false measurement...
measure from top of wheel lip to inside the top of the fender arc.
for the rear just check out this site belltech
