Just Joel Posted June 14, 2011 Report Share Posted June 14, 2011 Quick question, I have a zx or truck long tail five speed and I need to know what application speedo cable works with a 71 510' and this combo. Thanks Joel Quote Link to comment
haubstr Posted June 14, 2011 Report Share Posted June 14, 2011 I used the one from an automatic 510 since it reaches to the far side like the 280ZX trans... I been running it for years... Quote Link to comment
datzenmike Posted June 14, 2011 Report Share Posted June 14, 2011 Any 4 or 5 speed 620, 280z or zx non turbo, 5 speed '80-'83 S110 (200sx), 4 or 5 speed 810/Maxinma gas or diesel, '80-'82 720 gas or diesel (maybe later ones) I swappes an FS5W71B into my 710 and used the short 4 speed cable. Had to move it from the driver's side to the pass side and it still reached, so the 610 should also, as well as the A10 4 and optional 5 speeds and the S10 doglegs. Long 4 ans 5 speeds are best. Quote Link to comment
Stupid_fast Posted June 15, 2011 Report Share Posted June 15, 2011 I just used a ZX speedo cable. seems to some extra length which makes it easy to tuck around the engine bay. Though I have not seen what a 4spd cable length is like. Quote Link to comment
datzenmike Posted June 15, 2011 Report Share Posted June 15, 2011 The 4 and 5 speeds are the same length so .... should be the same length. Quote Link to comment
Just Joel Posted June 15, 2011 Author Report Share Posted June 15, 2011 Alright, two more questions... I measured my stock cable at sixty two inches but rock auto lists theirs at seventy for the 510 app. Is this the length for the auto and is that long enough the reach at only eight inches longer? Also, rock auto had both an upper cable and a lower cable listed for the zx. Do I need both parts or just the lower? Thanks Joel Quote Link to comment
datzenmike Posted June 16, 2011 Report Share Posted June 16, 2011 The 510 4 speed had the speedo on the driver's side which is the shortest distance to the dash gauge. I believe the autos are all on the pass side and although both trannys are similar in length the automatics would likely be slightly longer. Now..... On my 710, the 4 speed is basically the same length and type as the 510. I swapped in a zx 5 speed and simply routed the cable down the pass side of the tranny to the pinion. It fit without kinking it and has been to Canby no problems. The zx 5 speed pinion is only about 2" further back. That's nothing. Also, rock auto had both an upper cable and a lower cable listed for the zx. Do I need both parts or just the lower? Don't know about upper and lower but the zx did have 4 possible transmissions. The 4 and 5 speed standards, the three speed automatic and the T-5 BW 5 speed for use on the turbo equipped L28. The 4 and 5 speed would be the same length and likely the same as the automatic. The BW T-5 is a wild card and likely different. Quote Link to comment
