ohio510 Posted May 27, 2011 Report Share Posted May 27, 2011 so went to change header down pipe gasket because I have a bad exhaust leak there. took it apart and put the new gasket in simple enough right. bwahahahaa the reason it leaked iz because one of the studs is striped at the end wa wa wa...... so quick fix drill and through bolt cause I'm gonna do a swap when their is a foot of snow for 5 months or don't be a duche and fix it right. ps I'm broke now Quote Link to comment
izzo Posted May 27, 2011 Report Share Posted May 27, 2011 You can get away drilling it and using a bolt man. Just make sure its high grade to some what withstand the heat for a while. Quote Link to comment
datzenmike Posted May 27, 2011 Report Share Posted May 27, 2011 I used stainless and they don't rust and become difficult to remove later. Quote Link to comment
ohio510 Posted May 27, 2011 Author Report Share Posted May 27, 2011 dont get me wrong i wanna fix it right just investing in a new header is not in the budget:unsure:. Any tips on getting the stud out? Quote Link to comment
