Rob W. Posted April 29, 2011 Report Share Posted April 29, 2011 Wasn't sure where to put this because The problem is the engine but its on an 87 Maxima so here it is. I bought this 87 Maxima for $100 and I am having a strange problem. Sometimes it will start and run fine and then it sometimes it won't. It will die after starting when you drive it around the block, won't even make it home. The motor feels fine when its running. oh before I forget here's a pic I have determined it is a spark issue not fuel. So replaced the coil and still same problem so I returned it. Checked the crank angle sensor and it's cycling 0-5volts at the right times there is a finned little electrical bit under the coil that feeds power to the coil but it always seems to have 12 volts coming out of it. Any ideas or does anyone know where I can find an engine electrical diagram. The shop manual I have only has the chassis electrical, stupid Haynes. Help please Quote Link to comment
Pumpkn210 Posted April 29, 2011 Report Share Posted April 29, 2011 I would run it till it dies, then check for power. Whatever it is should be fairly easy to find when its actually doin it. Quote Link to comment
ggzilla Posted April 29, 2011 Report Share Posted April 29, 2011 Bad ignitor, which is the finned transistor under the coil. They have them at the pick-n-pull, like $10. Quote Link to comment
Rob W. Posted April 29, 2011 Author Report Share Posted April 29, 2011 could it be bad and still pass voltage. The book doesn't even show it as being there so no way to test it... What do you think? Quote Link to comment
Rob W. Posted May 2, 2011 Author Report Share Posted May 2, 2011 Bump any ideas Quote Link to comment
datzenmike Posted May 2, 2011 Report Share Posted May 2, 2011 Down load the fault codes. Quote Link to comment
jonesy510 Posted May 2, 2011 Report Share Posted May 2, 2011 maybe just a lose connection someplace in the system. perhaps sometimes is has just enough of a connection the the engine will run fine but other times the vibration of the engine and road will disrupt the connection causing it to die hence the reason it dies after going around the block.. i would start at checking and cleaning all the connections for the ignition system.. Quote Link to comment
