Javin Posted April 27, 2011 Report Share Posted April 27, 2011 According to Rock Auto and kybshocksonline the parts I need are as follows: KYB Part # 343208 GR2 RWD; Front KYB Part # 344046 GR2 RWD; Rear However Amazon (lowest price for those part numbers) disagrees. Are KYBs good for just a standard replacement? Anyone have any experience with these before I pull the trigger? Are these the right part numbers? What other common parts are usually replaced in regards to suspension? Oics of the way it looks nowish. Quote Link to comment
]2eDeYe Posted April 27, 2011 Report Share Posted April 27, 2011 Hard to tell with all the dirt. At the least you need to get some new boots for those tie-rod ends, dirt will kill them quick. KYB makes some decent shocks :) Quote Link to comment
Javin Posted April 29, 2011 Author Report Share Posted April 29, 2011 My rear shock absorbers came in today. Quote Link to comment
BenJammin Posted May 11, 2011 Report Share Posted May 11, 2011 Ball joints, tie rod ends, center link, and idler arm would be top on my list if I were you. Quote Link to comment
Javin Posted May 11, 2011 Author Report Share Posted May 11, 2011 That would be the plan. You can see how tortured everything is. Quote Link to comment
BenJammin Posted May 11, 2011 Report Share Posted May 11, 2011 Sounds like you got it all figured out already so bushings shouldn't be much of a leap from there. Quote Link to comment
yello620 Posted May 11, 2011 Report Share Posted May 11, 2011 Those shocks pictured are not rear shocks for a Datsun 620. Sorry. might be the fronts, but look a little long for the front. Quote Link to comment
Javin Posted May 11, 2011 Author Report Share Posted May 11, 2011 Those shocks pictured are not rear shocks for a Datsun 620. Sorry. might be the fronts, but look a little long for the front. Well I have them, so I will see if they fit anywhere. If not, I will send them back. Thanks for the heads up. Quote Link to comment
79funky620 Posted July 8, 2011 Report Share Posted July 8, 2011 Well I have them, so I will see if they fit anywhere. If not, I will send them back. Thanks for the heads up. How did the install go? I just got a set of KYBs and plan to get them in soon. Quote Link to comment
Javin Posted July 8, 2011 Author Report Share Posted July 8, 2011 hmm... Maybe I should get around to actually installing them, eh? Hah, they have been sitting in their box for a while. Sorry, I am of no help. :rolleyes: Quote Link to comment
