weber carburetor upgrade help
70 ARC DATS
  • Replies 9
Crank case vent tube connected to the PCV valve at base of carb. See if there's an opening on that cross tube on the new manifold that you can screw the PCV valve into. My SU intake has one....
It's the black braided hose in the middle with the gear clamp.
