FATSUN Posted March 25, 2011 Report Share Posted March 25, 2011 Hi can anyone tell me if the a12 head is a straight bolt on fitment to an a15 block .. I know its not as good as the oval port but have bike carbs on the 1200 engine & janspeed exhaust , so just as a try out why i get new headers/ inlet constructed i want to really run the engine. thanks in advance Quote Link to comment
Pumpkn210 Posted March 25, 2011 Report Share Posted March 25, 2011 Yes it is! :cool: Quote Link to comment
FATSUN Posted March 25, 2011 Author Report Share Posted March 25, 2011 thats good news heres a pic of the carb Sweeeeeeeeeeeeeeeeeeeeeeeeeeeeet what do you think??? Quote Link to comment
Pumpkn210 Posted March 25, 2011 Report Share Posted March 25, 2011 %100 Pure Hotness! Nice intoke by the way :wub: I eventually want to go to a quad carb setup, moneys are the only restriction! Quote Link to comment
FATSUN Posted March 25, 2011 Author Report Share Posted March 25, 2011 Ive got to get a new inlet made the other set up cost me £750 thats R1 carbs ,bespoke manifold ,fuel pump and pipercross air filter . Not sure if i should fit webers ive got the carbs just need to source oval manifold ....you just cannot get in the uk Anyone over there got one for sale??? Quote Link to comment
KELMO Posted March 26, 2011 Report Share Posted March 26, 2011 you lucky right hand drivers with all that room on the left side....no br master, no cl master to get in the way of some cool carbies :P Quote Link to comment
FATSUN Posted March 26, 2011 Author Report Share Posted March 26, 2011 Indeed lots of room do you think the bike carbs or webers on the A15 ??? Quote Link to comment
KELMO Posted March 26, 2011 Report Share Posted March 26, 2011 I think bike carbs because they look cooler (just my opinion). Have you looked on datsun1200.com? Quote Link to comment
FATSUN Posted March 26, 2011 Author Report Share Posted March 26, 2011 yes a great site , information over load Quote Link to comment
Duncan Posted March 26, 2011 Report Share Posted March 26, 2011 Hi can anyone tell me if the a12 head is a straight bolt on fitment to an a15 block .. I *think* they do, but I seem to remember something about checking to make sure you aren't blocking any coolant passages. I believe some heads have them, and some don't. Datsun 1200 dot com is a good place for swap info on that. Quote Link to comment
FATSUN Posted March 30, 2011 Author Report Share Posted March 30, 2011 I *think* they do, but I seem to remember something about checking to make sure you aren't blocking any coolant passages. I believe some heads have them, and some don't. Datsun 1200 dot com is a good place for swap info on that. on the 1200 site someone quoted: (You CAN use the early [front distributor] head on the later cylinder block as the oil feed to the rockers is pumped directly up the correct head bolt hole in the cylinder head. You can NOT use the later head on the early block because the early block feeds the rocker oil to a small vertical drilling at the side of the cylinder head gasket face. The cylinder head needs a corresponding drilling that feeds the oil across to the same cylinder head bolt hole as the later engines. Since the newer heads do not have the drillings necessary to pick up the early engines oil feed, the rockers will not get any oil at all with predictable results.) Ive since checked oil feeds head seems the same , time will tell Quote Link to comment
