Stitebunny Posted March 21, 2011 Report Share Posted March 21, 2011 Hi guys, I have a 70 510 wagon with an automatic and am wondering what fluid type to use in it. I have a Haynes owners workshop manual and it says Castrol TQF. It looks like this was a product for Ford's and I've read a few times that the ford stuff shouldn't be used. I tried doing a search and didn't come up with a definitive answer. What do you guys recommend? Thanks Quote Link to comment
ggzilla Posted March 21, 2011 Report Share Posted March 21, 2011 510s used two different automatics. My 1969 used a Borg Warner automatic. For the JATCO type, Automatic T/M Fluid: Type DEXRON (3N71B A/T) From my 1972 Datsun Owners manual (Daily Care page), these were recommended: * CHEVRON A.T.F. * ESSO A.T.F. * MOBIL A.T.F. 220 * SHELL A.T.F. DEXRON * SUNOCO Transmission Fluid DEXRON Type * TEXACO Texamatic Fluid DEXRON Any DEXRON compatible will work, including: * DEXRON 6 * DEXRON III/MERCON The bottle should say something like "Suitable for use in applications calling for DEXRON Quote Link to comment
datzenmike Posted March 21, 2011 Report Share Posted March 21, 2011 Must be Dexron type. Any brand you wish. Castrol TQF is European I think and may not be available. I believe all Dexron type I, II, III, VI are reverse compatible. It has been reformulated many times and improved over the years. Quote Link to comment
ggzilla Posted March 21, 2011 Report Share Posted March 21, 2011 Actually, one of those Dexrons is compatible with Ford Type F. So read the label carefully. Quote Link to comment
datzenmike Posted March 21, 2011 Report Share Posted March 21, 2011 I think it's some Ford transmissions are compatible with Dexron III and above. Quote Link to comment
Stitebunny Posted March 21, 2011 Author Report Share Posted March 21, 2011 Okay thanks. That's kind of what i thought. Just wanted to be sure. We have Dexron III in a bulk drum at work. It is a Borg Warner column shift. Quote Link to comment
ggzilla Posted March 21, 2011 Report Share Posted March 21, 2011 So what ATF does the Borg Warner require? Quote Link to comment
datzenmike Posted March 21, 2011 Report Share Posted March 21, 2011 Good question zilla. 3N71Bs were used after '71. There B/W units were smilar to Brttish ones in Austins and such. Quote Link to comment
RAlly_DatoB210 Posted March 21, 2011 Report Share Posted March 21, 2011 In the old b210 trans that was in my car i used wolfshead ATF. I can try and scrounge up another bottle for the exact title. Got 6 quarts from a friends transmission shop. Stuff works amazing litterally fixed what I thought was a bad transmission and everytime I check it comes bag clear as the day I poured it in. Quote Link to comment
Stitebunny Posted March 21, 2011 Author Report Share Posted March 21, 2011 Sorry I'm confused now. So the Borg Warner needs a special type of Dexron? Not just any kind will do? Quote Link to comment
ggzilla Posted March 21, 2011 Report Share Posted March 21, 2011 Most Borg Warner automatics are specified for Type F -- not Dexron. Of course as mentioned before some type of Dexron #? claims to be compatibile with Type F. But most types of Dexron are incompatible. Check your 510 owner's manual, it will list what you need. Or, check the automatick dipstick, it may be stamped what kind of fluid to use. Quote Link to comment
Stitebunny Posted March 22, 2011 Author Report Share Posted March 22, 2011 I looked in the owners manual which has an issue date of September 30th 1969. The car has a production date of 12/69. It has a Borg Warner full automatic. I'm still not sure what to put in it based on what has been said here. To me, all of these sound like regular old ATF Dexron and the transmission is not specified to have a Type F fluid. Was there a cutoff date where they changed the fluid type in the Borg Warner's maybe? The manual recommends: Texaco Texamatic Fluid 6673 Castrol TQ Dexron BP Autran DX Mobil ATF 220 Shell ATF Dexron Sorry, I know it shouldn't be this difficult. I just don't want to cause more problems with the transmission. It's low on fluid and I need to fix that before further diagnosis. Thanks again. Quote Link to comment
ggzilla Posted March 22, 2011 Report Share Posted March 22, 2011 Yes, your owner's manual says Dexron. That's Dexron I. So just go to the parts store and get something compatible. Read the bottle, probably Dexron 4 or somethign is compatible. Quote Link to comment
Stitebunny Posted March 22, 2011 Author Report Share Posted March 22, 2011 Thanks a lot. I'll see what I can find. I appreciate the help. Quote Link to comment
