Occasional loss of power?
metalmonkey47
I've noticed in my 210, occasionally when I leave work or go for a drive, when I pull away in the first two gears around 3500rpm I start to experience some pretty severe missfiring for a few seconds. It's not a matter of the engine being cold, because if I was to let it sit for 5 minuets after going for a long drive (20 minuets or so) when I start it up and go for a drive, I still have a problem.
Now, I know problems usually occur when something changes. The only things I've done recently was set the timing to 10 degrees, new plugs, fuel filter, and re-adjust the valves. None were really very recent (all within a month or so) but maybe it's relevent?
Any ideas?
This engine really needs to godry.gif It's getting to be a headache. i wish the PO took better care of her.
EDIT: forgot to mention it only does it once. Once It missfires and acts like an ass, it never does it again for the rest of the drive.
Edited by metalmonkey47
  • Replies 5
Inspect the rotor and the cap. If the plug wires are similar length, trade them around. See if it goes away.
Rotor is brand new as of about 4 months ago. Only about 500 miles on it. Cap appears to be good. No obvious corrosion. Not sure about the history on the wires though. All I know is they're bosch. I'll probably replace them tomorrow.
I pulled the wires off today to put on some new Accel 8mm wires, and when I pulled the wire off the coil, lots of nasty dirt and rust fell out. i grabbed some steel wool and di-electric grease and cleaned it up. Now it's not showing anymore problems thumbup1.gif
  • 3 weeks later...
