650savag Posted March 14, 2011 Report Share Posted March 14, 2011 I pulled the valve cover off and was going to check the valve lash on my truck (L20B). I may be wrong, but it looks like I will need a special wrench to loosen the lock nuts. I may be looking at the wrong hex shaped nut. It is a thin hex nut and it looks like a fairly large metric size. I don't have a metric wrench that big (maqybe a 20 or 21 mm) and it looks like it will need to be off-set some because the nut is almost level with or below the surface of the head. I understood from reading some of the helps and looking in my repair manual that the lock nut was a 17 mm and the hex that you turn to increase or decrease the clearance was a 14 mm. Can someone give me some advice on this? Thanks, Dan Quote Link to comment
Sealik Posted March 14, 2011 Report Share Posted March 14, 2011 Voila... :D http://community.ratsun.net/topic/16539-l-series-valve-adjustment/ Quote Link to comment
datzenmike Posted March 14, 2011 Report Share Posted March 14, 2011 It's in the HOW TO section. Quote Link to comment
650savag Posted March 15, 2011 Author Report Share Posted March 15, 2011 Found the videos. Thanks everyone. Great videos! Quote Link to comment
Skib Posted March 15, 2011 Report Share Posted March 15, 2011 It's in the HOW TO section. imagine that :lol: Quote Link to comment
