how to replace a core support+inner fenderwell and upper frame
a100addict
  • Replies 5
donor core piece
after using the grinder to remove paint you will see low spots which are the factory spotwelds start by center punching welds
then drill out with 1/8th inch drill. i have found that short bits are better as they are stiffer these are from enco.thanx to mike k for these
cutting out spot welds with HF spot weld cutter. these worked good for 6 bucks. i cut over 100 spot welds with 1 cutter
cut out spotweld
  • 10 months later...
