Conan Posted March 1, 2011 Report Share Posted March 1, 2011 My rat is leaking tranny fluid from the connection between the tranny and driveline (right by the 4 bolts that connect the driveline on the tranny side) right below the gear shifter. I was just wondering what part number/name of the seal that i need so that i can order a new one from RA, and will i also need a new bearing? Thx in advance :) Quote Link to comment
DanielC Posted March 1, 2011 Report Share Posted March 1, 2011 I forgot who posted this link yesterday, but I would suggest you bookmark it> http://www.carpartsmanual.com/datsun520/Datsun520521Index.aspx This is the page with the transmission case in it. http://www.carpartsmanual.com/datsun520/Datsun520521Index/PowerTrain/TransmissionCase/FromOct65/tabid/1456/Default.aspx The seal I think is item 18, down below the pictures. Clicking on the number listed for the seal, gives you this page. http://www.carpartsmanual.com/datsun520/Datsun520521Index/PowerTrain/TransmissionCase/FromOct65/tabid/1456/Default.aspx 32136-07200 Or it might be, 32136-E0100 Quote Link to comment
Conan Posted March 2, 2011 Author Report Share Posted March 2, 2011 (edited) I forgot who posted this link yesterday, but I would suggest you bookmark it> http://www.carpartsm...20521Index.aspx This is the page with the transmission case in it. http://www.carpartsm...56/Default.aspx The seal I think is item 18, down below the pictures. Clicking on the number listed for the seal, gives you this page. http://www.carpartsm...56/Default.aspx 32136-07200 Or it might be, 32136-E0100 Thank you ! :) The part costs $1.46; shipping on the other hand is $29.76..... are there any alternatives to RA that are closer to Norway (anything in europe?) Edited March 2, 2011 by Conan Quote Link to comment
banzai510(hainz) Posted March 2, 2011 Report Share Posted March 2, 2011 place in England. Datsunworld or something like thatIm sure its common with the other old datsuns like a Z car also http://www.datman.co.uk/ you got to remove the drive line.so you go to loosen up the carrier bearing. I believe there is a bug hex nut that needs to be removed to pull the 4 bolt flange off. its alot of work for a 5 min job replacing the seal. Quote Link to comment
