erikcarter Posted February 23, 2011 Report Share Posted February 23, 2011 Has anyone ever heard of this LSD? they say it will go into a H190 I just wonder about the spline count http://shop.phantomgrip.com/products.php?product=ALL-NISSAN-%28-H190%29- Quote Link to comment
Laecaon Posted February 23, 2011 Report Share Posted February 23, 2011 Has anyone ever heard of this LSD? they say it will go into a H190 I just wonder about the spline count http://shop.phantomgrip.com/products.php?product=ALL-NISSAN-%28-H190%29- Heard of them, read they are junk. If you want LSD go with a Ford, Toyota truck, or RX7 rear end. Quote Link to comment
erikcarter Posted February 23, 2011 Author Report Share Posted February 23, 2011 That sucks, I was hopeing it would work, I guess I will stick with the toyota rearend. Quote Link to comment
datzenmike Posted February 24, 2011 Report Share Posted February 24, 2011 Each Phantom Grip unit is assembled with pressure tested matched sets of progressive-rate springs to achieve equal load distribution to the disc plates, which dramatically enhances reliability and performance. Beware!!! Those do not have clutches but instead use high pressure springs to jam the side gears back against the thrust washers to increase the friction. There are no 'disc plates' in the differential nor do they supply them. That's metal to metal wear of parts not designed nor intended for this. Quote Link to comment
