Hdlstrky Posted February 6, 2011 Report Share Posted February 6, 2011 Hi im new to the forum been reading up on puting a vg30e in a 521 and havent been able to find anyone who has done it. If i missed it somewhere sorry i thought i scoured the forum. But anyways i have just bought a 72 datsun 521 and i have a 84 nissan 300zx with vg30e in it the rust demons have ate the car but the truck is in decent shape (sry no pics yet i havent pulled it out of the snow) pics will be coming soon. So now to the meat of my question, has anyone done this swap and what am i going to be running into for problems here? Any parts i should be looking for? Any help would be great i know its kind of a broad question but thanks for any replys. Quote Link to comment
hobbes_the_cat Posted February 6, 2011 Report Share Posted February 6, 2011 A few guys make "kits" for the 510, but i think you will need to do some fabricating for a 521. most likely some mods to the oil pan or front cross member. the 510 requires a shorter intake to clear the hood. i would assume that many of the issues you would run into with a 510 would be similar with a 521, as the engine bays are similar sized. EFI wiring should be no problem if you follow Icehouse's diagrams or use his kit. Quote Link to comment
wayno Posted February 6, 2011 Report Share Posted February 6, 2011 Yellow620 has done/is doing this to an early 620 frame which is basicly the same frame, I was unable to find a thread for his build, I have seen it, maybe he will post to this thread, it has the right title to interest him I beleave. wayno Quote Link to comment
yello620 Posted February 6, 2011 Report Share Posted February 6, 2011 Yes, i have startted this conversion. The motor and trans fits reasonably well in the 620. I have no idea how it will fit the body of the 521 though. I had to custom build the oil pan to clear the crossmember and steering. Went through 6 or 7 starters before i found one the one i settled on, does not run yet so we will see how it works out. Alternator clearance to the idler arm is a major problem too. There is a link to my build in my signature. Quote Link to comment
Hdlstrky Posted February 6, 2011 Author Report Share Posted February 6, 2011 Well it seems like i have set off on a fantastic voyage :) I will take tons of pictures of the full build from tip to tail. Thanks for the replys and good luck with your build yello. Quote Link to comment
