inline4 Posted February 2, 2011 Report Share Posted February 2, 2011 thanks in advance. Link to comment
wayno Posted February 2, 2011 Report Share Posted February 2, 2011 What are you using it for, a roadster application? Did your lower bearing tear up yours? let me know. wayno Link to comment
inline4 Posted February 2, 2011 Author Report Share Posted February 2, 2011 yeah I want to use it for a roadster ka hybrid transmission. Link to comment
datzenmike Posted February 2, 2011 Report Share Posted February 2, 2011 The one I had also had the larger 62mm counter bearing so should slip onto the KA tranny. It also had a steel front cover plate. The first I've ever seen, usually they are cast aliminum. Link to comment
wayno Posted February 3, 2011 Report Share Posted February 3, 2011 Only the diesels had the steel cover that I know of. There is another thread (need 720 parts SD-22) in this section that a guy is looking for parts, one of the guys(DREWSDIME) responding to the thread says there is a SD22 diesel truck in a wrecking yard in Upland ca. Is this close to you? I would jump on this. wayno Link to comment
inline4 Posted February 3, 2011 Author Report Share Posted February 3, 2011 I'm no longer in so cal. if someone wants to pull it and hold it for me, I could swing on by during one of my so cal trips :o Link to comment
