BayAreaDimer Posted January 16, 2011 Report Share Posted January 16, 2011 i recently painted my 2 door and pulled out the engine to get the engine bay. Now, none of the lights turn on or gauges work, the engine turns on and stays on but also my stereo wont stay on unless i have jumpers connected to the battery, i recently put in a new volt regulator, it was used, could this have anything to do with the issues any advice will help. thanks Quote Link to comment
Jesse C. Posted January 16, 2011 Report Share Posted January 16, 2011 Did you make sure all your grounds are good? Did you clean off the paint where the wires need to ground to the chassis? Small things,but, they do add up! Quote Link to comment
banzai510(hainz) Posted January 16, 2011 Report Share Posted January 16, 2011 volt reg has nothing to do with the radio. that I know of. the headlights should be wired up to the battery. meaning take a test light and ground one end and put the pointer end on the lamp connection.(with swithc OFF). all the connection should light up with test light. So its a ground proplem either threw the realy or the swithc to ground. make sure the ground at the volt reg is good. I think there is a ground by the hood release not sure. Quote Link to comment
