Dirk Diggler Posted January 13, 2011 Report Share Posted January 13, 2011 Just curious as to what LSD everyone recommends for a 70 240. I know that the r200 is a popular choice, but does anyone have any experience with anything else? Quote Link to comment
SHADY280 Posted January 13, 2011 Report Share Posted January 13, 2011 if you have an r180, you could do a subi lsd like the 510 guys. lots of links here bout it. r180 is plenty strong Quote Link to comment
MicroMachinery Posted January 13, 2011 Report Share Posted January 13, 2011 Finding an R180 LSD? If you've got over a grand to spend on a differential, go for it. Quote Link to comment
datzenmike Posted January 13, 2011 Report Share Posted January 13, 2011 Just curious as to what LSD everyone recommends for a 70 240. I know that the r200 is a popular choice, but does anyone have any experience with anything else? The S31used a clutch LSD R 200 3.70 but they are HEAVY! The Z31 can also use, and all Z32 use a viscous LSD I think Quote Link to comment
Dirk Diggler Posted January 15, 2011 Author Report Share Posted January 15, 2011 I have an r180, are the stock datsun r180s lsd? I keep finding conflicting info on them. I have found that a r180 lsd from a wrx sti is the same dimensions as the z r180, would this be my best bet when it comes down to funds and the ammount of work? Quote Link to comment
datzenmike Posted January 15, 2011 Report Share Posted January 15, 2011 I have an r180, are the stock datsun r180s lsd? I keep finding conflicting info on them. I would say no, not stock. WRX it is. Quote Link to comment
SHADY280 Posted January 16, 2011 Report Share Posted January 16, 2011 z32 is a different spline i believe. z31 works tho, grab the axles too. but yeah subi stuff is said to be the same. i wouldnt buy new, like micro said, expensive. Quote Link to comment
Mr.Woof's72z Posted January 25, 2011 Report Share Posted January 25, 2011 R180 is what you currently have in your car (if it is stock), switching to an R200 won't for sure make it an LSD R200. There are numerous R200s out there, all with different gear ratio and LSD type: Clutch LSD vs. Viscious LSD. Depending on what car they came out of will depend gear ratio, whether or not it is LSD, and if so, which LSD it has (CLSD vs VLSD). Straight from www.datsunzgarage.com which I have had helped me a TON: R200 gear ratio: '75-79 280Z(X)s had a 3.54 '81-83 turbo ZX's had a 3.54 '81-83 non-turbo ZX's had a 3.90 the '85-86 200SX turbo had a 4.11 the '87-89 LSD was a 3.70 LIMITED SLIP DIFFERENTIALS Despite the performance of the Z, Nissan only made a limited slip diff very late in the Z's life. They made 2 types: a standard LSD and a LSD with a viscous internal drive. The 1987-89 Turbo 300ZX's had the "good" 3.70 LSD, and can be identified by it's finned rear cover. This cover needs to be replaced with the smooth R200 cover to fit properly to the 280Z mustache bar and the front driveshaft flange needs to be replaced with the one your driveshaft uses. The '88 white SE 300ZX came with the "viscous-drive" R200, and can be identified by a sticker on the driver-side of the diff that says "VISCOUS LSD". While the viscous model fits into an earlier Z, R200 halfshafts don't lock into them without some fabrication of new halfshaft fittings. Give us some more info on the car, what you're looking to get out of it (hopes and dreams and then something realistic), and we can help you out from there. I will be running an L28 (F54 bottom/P79 head), dome top SUs, '81 5 spd, '81 3.90 R200. Pretty much a bolt in application. R180 Subaru diffs work also (and possibly better), it was just much easier for me to work with what I have. Quote Link to comment
Dirk Diggler Posted February 2, 2011 Author Report Share Posted February 2, 2011 Info on the car: 70 240z All original except color My hopes are realistic for this car. I just want to get it looking as good as it did from the factory, with the addition of a few cosmetic and mechanical upgrades. The only changes I want to make mechanically are the rear diff, and rear rear sway bar. I only want to change those to improve the handling and driving pleasure. Pretty much I want to make the only changes needed to make an almost perfect car perfect. Quote Link to comment
