H5WAGON Posted January 11, 2011 Report Share Posted January 11, 2011 Just checking what calipers will bolt onto my 70 510 wagon struts. will the 710 or 200sx calipers work? They have the drop in style pads. They look the same but I don't want to buy them if they wont work...;) Thanks....I saw a thread about this sometime ago, but could not find it?..:( The 710 is a 76 and the 200sx is a 79. Quote Link to comment
INDY510 Posted January 11, 2011 Report Share Posted January 11, 2011 . In september 1975 the 710 calipers changed ......... .. I have the early '75 calipers and they are similar to 510 calipers But the '76 calipers will probably have different shaped pads....... .. and I don't know if that will work 1971 510 caliper and rotor on the left ............. .. (pre-09/75) Early 1975 710 caliper and rotor on the right ..... (rotors have a larger center bore) Maxima on the left . . . . .. . ... .. 1976 710 on the right ........ you can see the whole caliper is totally different than a early 75 caliper: Quote Link to comment
H5WAGON Posted January 14, 2011 Author Report Share Posted January 14, 2011 yo, thanks....Yea the pads are different shaped.....But the mounting holes are the same for the calipers so I may give it a shot, if not I will have some credit at the yard. Quote Link to comment
datzenmike Posted January 14, 2011 Report Share Posted January 14, 2011 Maxima on the left . . . . .. . ... .. 1976 710 on the right ........ you can see the whole caliper is totally different than a early 75 caliper: INDY we must have the same mother. Maxima strut on left '74 710 on tight '74 710 caliper and angled pads. My info says Aug. '75 was when the difference started. (I know, hair splitting) . Quote Link to comment
H5WAGON Posted January 14, 2011 Author Report Share Posted January 14, 2011 I'm thinking they will work.....rotors look the same size. Quote Link to comment
