280zx turbo dizzy and oil pump shaft wanted
  • Replies 16
So the difference is either 81 or 82/83? Basically internal and external cas?
ya 81 has dizzy that only has a rotor in it and an external CAS and the 82/83 set ups have the CAS in the dizzy.
either way tho you need to have the dizzy matching the year of your ECU and harness
np, lol be glad you got the internal stuff.
the external CAS is a PITA.
its mounted on the front of the crank with a trigger wheel and you have to set the trigger wheel/CAS gap with a fuckin feeler gauge.
I had that one mine and had a big ass front mount and I had to take all my IC piping off, set it, put it back on, test it.
and it if wasnt right I had to do it all over again.
