akumazedex Posted January 7, 2011 Report Share Posted January 7, 2011 Looking for a turbo distributor and oil pump shaft for a 280zx turbo to finish up my na/t swap. Let me know if anyone has. Thanks Link to comment
Zeusimo Posted January 7, 2011 Report Share Posted January 7, 2011 There's One In The Modesto Pick And Pull, Has All Engine Components Link to comment
akumazedex Posted January 7, 2011 Author Report Share Posted January 7, 2011 Does it matter? Mines an 82 na Modesto is kindu far. But I migh treck out there this weekend if I must. Link to comment
akumazedex Posted January 10, 2011 Author Report Share Posted January 10, 2011 Modesto does not have a turbo 280... <_< nor does Stockton. A lot of na's tho. Pick n pull quest failed. Hey Skib, you got a dizzy? Still looking for one Link to comment
Skib Posted January 10, 2011 Report Share Posted January 10, 2011 Does it matter? Mines an 82 na yes, very much. what year turbo is the ECU and wiring out of? Link to comment
datzenmike Posted January 10, 2011 Report Share Posted January 10, 2011 Skib didn't the turbo use a CAS and the NA just a matchbox? Link to comment
akumazedex Posted January 10, 2011 Author Report Share Posted January 10, 2011 Hmm I'll see if I can find out what year it is, it's a remanned one so I'll see what I can find out from the part numbers Link to comment
Skib Posted January 10, 2011 Report Share Posted January 10, 2011 Skib didn't the turbo use a CAS and the NA just a matchbox? ya an N/A 280zx dizzy just has the matchbox while the 81 turbo has an external CAS with a trigger wheel and the 82/83 turbos have an internal CAS Link to comment
akumazedex Posted January 10, 2011 Author Report Share Posted January 10, 2011 So the difference is either 81 or 82/83? Basically internal and external cas? Link to comment
Skib Posted January 10, 2011 Report Share Posted January 10, 2011 So the difference is either 81 or 82/83? Basically internal and external cas? ya 81 has dizzy that only has a rotor in it and an external CAS and the 82/83 set ups have the CAS in the dizzy. either way tho you need to have the dizzy matching the year of your ECU and harness Link to comment
akumazedex Posted January 10, 2011 Author Report Share Posted January 10, 2011 Ok ecu is out of an 82 turbo auto. Same as the harness Link to comment
Skib Posted January 10, 2011 Report Share Posted January 10, 2011 Ok ecu is out of an 82 turbo auto. Same as the harness ok the turbo dizzy I have woulnt work then you need an 82 turbo dizzy with the internal CAS Link to comment
akumazedex Posted January 10, 2011 Author Report Share Posted January 10, 2011 Allrightythen, well thanks for clarifying things for me. Link to comment
Skib Posted January 10, 2011 Report Share Posted January 10, 2011 np, lol be glad you got the internal stuff. the external CAS is a PITA. its mounted on the front of the crank with a trigger wheel and you have to set the trigger wheel/CAS gap with a fuckin feeler gauge. I had that one mine and had a big ass front mount and I had to take all my IC piping off, set it, put it back on, test it. and it if wasnt right I had to do it all over again. Link to comment
akumazedex Posted January 10, 2011 Author Report Share Posted January 10, 2011 Wow, you poor soul haha well I got luck on this one then, i never thought it would be that bad Link to comment
akumazedex Posted January 17, 2011 Author Report Share Posted January 17, 2011 alright, so I got a turbo dizzy and shaft today locally from a member on hybridz, thanks everyone for your offers. And yes, this is the correct one. Link to comment
