troyt Posted January 7, 2011 Report Share Posted January 7, 2011 Lost my notes, and no good search results... What is the closest stock driveshaft to look for to fit in a '70 510 with a 280z 5 speed and a L20b? Thanks Quote Link to comment
datzenmike Posted January 7, 2011 Report Share Posted January 7, 2011 I don't think there is one that will fit that is close enough. So shortening your stock one is the only real option. Too bad you don't have a goon. I hear that the sedan driveshaft is within 1/2" of the ideal length if you put a 620 or 280z/zx 5 speed in it. Quote Link to comment
troyt Posted January 7, 2011 Author Report Share Posted January 7, 2011 Thanks Mike. The project is for my race goon that has an IRS in it. I'm running a flanged output Comp 5 speed with a modded Roadster driveshaft now, but my race-spare trans is a splined Z 5-speed that I need to put a driveshaft together for. I don't have any driveshafts, just trying to figure which one to track down. Sounds like a shortened 510 4-speed shaft might be the ticket. Quote Link to comment
hang_510 Posted January 8, 2011 Report Share Posted January 8, 2011 Sounds like a shortened 510 4-speed shaft might be the ticket. :thumbup: Quote Link to comment
datzenmike Posted January 8, 2011 Report Share Posted January 8, 2011 If both transmissions are the same length, could you not just unbolt the spline from the comp unit and bolt it back on the drive shaft and run it in the end of the 280zx tranny? Quote Link to comment
troyt Posted January 9, 2011 Author Report Share Posted January 9, 2011 If both transmissions are the same length, could you not just unbolt the spline from the comp unit and bolt it back on the drive shaft and run it in the end of the 280zx tranny? The early 'A' comp trans has no output splines at all, just a flanged plate bolted onto the threaded output shaft. So I use a Roadster driveshaft with a splined two-piece tube. Hmm, I guess I could take another two piece driveshaft and have a splined end welded on istead of the flange and only have to carry one third of a driveshaft with my spare trans. Quote Link to comment
