Slide-sun Posted December 27, 2010 Report Share Posted December 27, 2010 Hey everyone currently building a 510 wagon with an SR power plant. I was originally going to use the conversion from datsport but now I found the one on mad dat. has anybody used either one.. or does anybody know of others? which one is recommended? obviously datsports one has a lot more but is it worth the extra 500 bucks? Quote Link to comment
vegas510 Posted December 27, 2010 Report Share Posted December 27, 2010 I have the datsport complete sr swap front end, I like it so far havent drove the car so dont know how she handles, Only thing I dislike is the front wheels stick out Quote Link to comment
Slide-sun Posted December 27, 2010 Author Report Share Posted December 27, 2010 how far? if you get a camber kit would they tuck? Quote Link to comment
dennis Posted December 27, 2010 Report Share Posted December 27, 2010 Why use either? If you cant do the fab work you can get someone to do it for you. Flip the front cross member run some 620 motor mounts and then buy a tranny mount (Engineered Datsun Products/Aaron sells them). DRG sells the front sway bar and bam you just saved yourself a bunch of money. You will have to source a radiator and intercooler along with a 240sx gas pedal. Shorten the driveshaft, cut and expand the shifter hole. It is of course not that easy to slap a SR20/KA24 into a 510 but the parts that you are getting from either McKinney/Datsport/Maddat are just going to cost you more especially since the dollar to AUD rate and shipping. With my current SR20DET swap I am at the early stages of my swap, I am just gathering the parts needed for the swap. Expect to spend around 6k for the swap if you do most of the work yourself (that is including engine) this is of course dependent on how good of a shopper you are, how much work you do yourself, and how wild your install is going to be. Plan well and do your research. Quote Link to comment
dennis Posted December 27, 2010 Report Share Posted December 27, 2010 how far? if you get a camber kit would they tuck? No they will not tuck with camber plates or adjustable lower control arms. People who run the Datsport kit run around 30et wheels on 7" wide rims. I am not 100% on the offset, maybe one of them can chime in. Quote Link to comment
Slide-sun Posted January 2, 2011 Author Report Share Posted January 2, 2011 ya I might go that way then.... I was looking at my car today and thinking what to do and the more and more I research I'm pretty sure I can do this my self... save the cash I'd spend on pre-made stuff and spend it on go fast stuff :D Quote Link to comment
HRH Posted January 2, 2011 Report Share Posted January 2, 2011 I've bought stuff from Datsport. The downside is shipping from AU. And parts aren't exactly cheap. Not that I'm complaining, you do get what you pay for. Quote Link to comment
BoostinBen Posted January 4, 2011 Report Share Posted January 4, 2011 I agree they are pretty easy to flip yourself if you know what you are doing. I happen to have gotten the MadDat kit and they are a really nice kit super clean welds all powdercoated and everything you need to bolt right up + a front swaybar.. but I happened across the kit here in the US for a steal is the only reason i got one.. I got my stock crossmember I took out and reversed it myself just for the heck of it.. turned out good not to much hassle to do.. Quote Link to comment
