Mini-L320 Posted December 10, 2010 Report Share Posted December 10, 2010 Selling away this Cute Little Garrett Ball Bearing Turbocharger Model: GT1752 Internal Wastegate/Max Boost is 8psi. Like always my mind goes in to different directions <_< $140 :hyper: Deal of a Life Time. Has minimal Shaft Play. Its both Water Cooled and Oil Cooled. Link to comment
wayno Posted December 11, 2010 Report Share Posted December 11, 2010 What size engine(cc) was this turbocharger intended for? wayno Link to comment
Mini-L320 Posted December 11, 2010 Author Report Share Posted December 11, 2010 What size engine(cc) was this turbocharger intended for? wayno These turbos I think came on Saab's. So maybe from 1800cc's- 2200cc's But for a turbo of this size, you can use it from a 1200cc threw 2.4ltr anything after that would be overkill for this Turbo. .53 A/R .47 Link to comment
wayno Posted December 12, 2010 Report Share Posted December 12, 2010 These turbos I think came on Saab's. So maybe from 1800cc's- 2200cc's But for a turbo of this size, you can use it from a 1200cc threw 2.4ltr anything after that would be overkill for this Turbo. .53 A/R .47 I do not know a lot about turbo chargers, I am going to turbocharge my nissan SD25 diesel engine. I have been l told that I need a turbo for a 1600 cc gasser engine, as diesels do not move air as fast I guess. I was also told that a T25 turbo would work, but I am to cheap to buy a new one until I know it will work. I have a airreaserch M10 that I got with a SD25 engine that I found on the side of this guys house in the mud, but the truck was scrapped for reasons I was not told. I had it running on a stand, but have no idea if the turbo was working, the guys that set it up kinda jury rigged it on the engine, real back yard stuff, they had the wastgate wired shut. I'm thinking the turbo was too big. Anyway, my engine is a 2500 cc diesel engine. Do you think your turbo will work for my application? wayno Link to comment
Mini-L320 Posted December 12, 2010 Author Report Share Posted December 12, 2010 I do not know a lot about turbo chargers, I am going to turbocharge my nissan SD25 diesel engine. I have been l told that I need a turbo for a 1600 cc gasser engine, as diesels do not move air as fast I guess. I was also told that a T25 turbo would work, but I am to cheap to buy a new one until I know it will work. I have a airreaserch M10 that I got with a SD25 engine that I found on the side of this guys house in the mud, but the truck was scrapped for reasons I was not told. I had it running on a stand, but have no idea if the turbo was working, the guys that set it up kinda jury rigged it on the engine, real back yard stuff, they had the wastgate wired shut. I'm thinking the turbo was too big. Anyway, my engine is a 2500 cc diesel engine. Do you think your turbo will work for my application? wayno On a Diesel engine it will work even better than on a gas. Just because Diesel Engines make Peak Power at very low RPM's and this Turbo since its a Ball Bearing will Spool pretty quickly. This is an Internal Wastegate turbo,meaning that is already set to 8 psi max of boost. Its a Garrett Turbocharger it aint no Ebay Cheapo Turbo, :P. Link to comment
metalmonkey47 Posted December 12, 2010 Report Share Posted December 12, 2010 Is this the one you made the turbo manifold for and put together??? Link to comment
Mini-L320 Posted December 12, 2010 Author Report Share Posted December 12, 2010 Is this the one you made the turbo manifold for and put together??? I was going to do it but, i never found the Exhaust Manifold that didnt connect to the carb. Link to comment
Mini-L320 Posted December 12, 2010 Author Report Share Posted December 12, 2010 Well if someone is Really Interested in it let me know, cause next Sunday 12/19 Im leaving to Mexico and wont be back until 1/18/2011 :D time to get my Groove On, hehe :hyper: $155 Shipped, :hyper: Will be packed in a Flat Rate Box. Link to comment
fo0manchu Posted December 12, 2010 Report Share Posted December 12, 2010 so that turbo has as t25 flange and is good for up to 250hp'ish max. Good price for turbo for a small engine. Link to comment
Mini-L320 Posted December 13, 2010 Author Report Share Posted December 13, 2010 so that turbo has as t25 flange and is good for up to 250hp'ish max. Good price for turbo for a small engine. Yup its a T25 Flange. For $155 Shipped for a Garrett Turbocharger, can go wrong. I'll rather see it go to someone who is gonna use it then to keep it here doing nothing. I got it covered up in a Bag so no Dust/debris gets inside of the turbines. Link to comment
