Gary Posted December 16, 2010 Report Share Posted December 16, 2010 nah i dont think it will, maybe pulling the other way though? steering wheel and shifter off it'll go the other way if you're tricky with maneuvering the column about so you can either drop or lift the steering box clear of the frame Quote Link to comment
kona480 Posted December 19, 2010 Author Report Share Posted December 19, 2010 nah i dont think it will, maybe pulling the other way though? steering wheel and shifter off it'll go the other way if you're tricky with maneuvering the column about so you can either drop or lift the steering box clear of the frame Yeah I might have to, I can't get the steering wheel off though. I cant use a puller because the only thing to hook it onto is the indicator switch and there is a warning sticker on the wheel saying don't hammer it. Is there another way other than just pulling like crazy? haha Quote Link to comment
Gary Posted December 19, 2010 Report Share Posted December 19, 2010 undo the middle nut nice, but undo it so the nut is about 2 or 3 turns before coming off completely (ie leave the nut attached onto the column, but so theres a nice gap on the shaft between the nut and the steering wheel now with the steering wheel, get some WD40/5.56/penetrant lubricant and using a rag to make sure it doesnt drip everywhere, give the splined bit a good blast. leave it for a little bit (a minute or so will do it), then get comfortable and start pulling, wiggle it off kinda thing so pull it back and forward one side at a time (side to side and up and down) and it'll come off fair easy. not so much about strength as it is about how you do it :D if you dont leave that nut off, the steering wheel will likely let go of the shaft nice and quick and the nut will stop it flying off and into your face. it hurts :P ive done it twice before learning my lesson hah so leave that nut on and you wont end up kissing the wheel Quote Link to comment
Greiggy Posted December 19, 2010 Report Share Posted December 19, 2010 undo the middle nut nice, but undo it so the nut is about 2 or 3 turns before coming off completely (ie leave the nut attached onto the column, but so theres a nice gap on the shaft between the nut and the steering wheel now with the steering wheel, get some WD40/5.56/penetrant lubricant and using a rag to make sure it doesnt drip everywhere, give the splined bit a good blast. leave it for a little bit (a minute or so will do it), then get comfortable and start pulling, wiggle it off kinda thing so pull it back and forward one side at a time (side to side and up and down) and it'll come off fair easy. not so much about strength as it is about how you do it :D if you dont leave that nut off, the steering wheel will likely let go of the shaft nice and quick and the nut will stop it flying off and into your face. it hurts :P ive done it twice before learning my lesson hah so leave that nut on and you wont end up kissing the wheel this man has the right idea :P Quote Link to comment
kona480 Posted December 19, 2010 Author Report Share Posted December 19, 2010 Yeah I sprayed some wd40 on it yesterday, this time it just came straight off, no pulling required. I also unbolted the steering box from the chassis. I just need to pull the column out then the cab should come off. I have 3 days of work left then 2 weeks off to get stuck into the datto : D Quote Link to comment
kona480 Posted December 31, 2010 Author Report Share Posted December 31, 2010 I finally got the steering column out, and the column shift. Now the cab is ready to come off so I am going to borrow a mates engine crane tomorrow, hopefully the crane and a few pwople will be enough to lift it off. After that is done I can get working on the chassis. Quote Link to comment
Charlie69 Posted December 31, 2010 Report Share Posted December 31, 2010 Great project. A stripped cab is about 600 pounds US weight. Quote Link to comment
kona480 Posted December 31, 2010 Author Report Share Posted December 31, 2010 Great project. A stripped cab is about 600 pounds US weight. cheers Quote Link to comment
kona480 Posted January 9, 2011 Author Report Share Posted January 9, 2011 Update time. It has been a while but I finally got some friends around to help lift the cab off. Now I can start cleaning up the chassis. Quote Link to comment
GOLSETH Posted January 9, 2011 Report Share Posted January 9, 2011 Wow! I wish I had the time and money to so this deep of a project. Quote Link to comment
kona480 Posted January 10, 2011 Author Report Share Posted January 10, 2011 Wow! I wish I had the time and money to so this deep of a project. Haha I havn't even spent any money on them yet. Apart from the cost of actually buying them. Quote Link to comment
