WTB l20B
  • Replies 10
im in ky, can you make a drive up here? i jusy pulled my l20b with 105,000 on the clock, runs great but could use some valve stem seals? maybe a little freshen up? i can do this for you as well
I'll be in Louisville next week, then possibly over to Cincinnati Dec 3-4. Braden, if you are on the way not far off of I-65, I-75 I'll pick it up for Metalmonkey, no freight!
For some reason I totally missed that post Braden.
Edited by metalmonkey47
i replied, the engine internals are actually pretty clean, the cam shows signs of slight wear, and before i pulled it i had just changed the antifreeze and i had just thoroughly flushed the oil with atf and it came out very clean. i can clean it up, and do whatever you need to it for you for cheap. im out of work so this would be fun for me, i could do new freeze plugs, clena it up, paint it whatever. let me know
