mcdatsun Posted October 29, 2010 Report Share Posted October 29, 2010 This truck has never had a radio. Need a radio and antenna and wiring. I would also like to know if anyone knows of a good aftermarket company that makes retro stereos with modern functioning like mp3 capability. Link to comment
Brian D Posted October 29, 2010 Report Share Posted October 29, 2010 how far do you want to go. I have a way I use at work to add I pod but you have to run a amp. It sounds much better than the fm mod pieces of junk Link to comment
raggmann Posted October 30, 2010 Report Share Posted October 30, 2010 My '72 came with an antenna but the p/o obviously installed it as the mounting hole is something to be seen. As far as the radio,I don't have a "factory" one in either truck BUT the green truck DID come with an 8trac. I plugged it in and the lights come on. I really hope the 8trac player works. Link to comment
mcdatsun Posted October 30, 2010 Author Report Share Posted October 30, 2010 how far do you want to go. I have a way I use at work to add I pod but you have to run a amp. It sounds much better than the fm mod pieces of junk I'm not looking for anything loud. Just a nice little setup that looks pretty stock. I'd like to keep the glove box as a glove box as well. Link to comment
KC Phirus Posted January 9, 2012 Report Share Posted January 9, 2012 Did you ever get one? Stock am/fm or tape Link to comment
Jester Posted January 10, 2012 Report Share Posted January 10, 2012 how far do you want to go. I have a way I use at work to add I pod but you have to run a amp. It sounds much better than the fm mod pieces of junk What do you do? Link to comment
Brian D Posted January 11, 2012 Report Share Posted January 11, 2012 I have a line driver with volume control that sends signal to the amp. You can take apart the factory radio and use the knob there Link to comment
