budsaipan Posted October 28, 2010 Report Share Posted October 28, 2010 Do anyone know where I can find intake manifold flanges? I need it for the r1 carbs that I want to put on my lz22. Quote Link to comment
datzenmike Posted October 29, 2010 Report Share Posted October 29, 2010 You mean an intake manifold? The flange is part of the intake and it bolts to the head surface. You could cut the manifold just before it narrows down to a single pipe and fit tubes between them and the carbs or weld aluminum tubes to extend them? Quote Link to comment
Xander_42 Posted October 29, 2010 Report Share Posted October 29, 2010 I don't know of anywhere that you can purchase them. But I'm working on designing an intake manifold for these heads. Once I get a design, I can send you a drawing (like drafting kind of drawing, not like sketch kind), and you could get some water jetted. This may not be the way you want to do it, but if that will work for you I'll send you a drawing once I make one. Quote Link to comment
Cuts metal like mad Posted October 29, 2010 Report Share Posted October 29, 2010 Make them, or have them made at a local machine shop. Use the stock L intake as a template. It needs to be the same thinkness, or your washers will be cocked sideways and you will have poor sealing. Quote Link to comment
budsaipan Posted October 29, 2010 Author Report Share Posted October 29, 2010 I tried cutting them but kinda messed up. I do have an extra intake manifold to cut the flange off but then don't want to risk it. I just can't seem to find a local machine shop that can do this. The machine shop here overcharges alot and they flat out told me they couldnt even cut the stock one. Quote Link to comment
budsaipan Posted October 29, 2010 Author Report Share Posted October 29, 2010 I don't know of anywhere that you can purchase them. But I'm working on designing an intake manifold for these heads. Once I get a design, I can send you a drawing (like drafting kind of drawing, not like sketch kind), and you could get some water jetted. This may not be the way you want to do it, but if that will work for you I'll send you a drawing once I make one. I'm very interested. Let me know when you get it done and I'll give you my email. Thanks!! Quote Link to comment
Cuts metal like mad Posted October 29, 2010 Report Share Posted October 29, 2010 bandsaw, drillpress, and burr for aluminum. you can do this. Quote Link to comment
sinner720st Posted October 29, 2010 Report Share Posted October 29, 2010 budsaipan Posted Today, 09:42 PM I tried cutting them but kinda messed up. I do have an extra intake manifold to cut the flange off but then don't want to risk it. I just can't seem to find a local machine shop that can do this. The machine shop here overcharges alot and they flat out told me they couldnt even cut the stock one. the machine shop you tried sounds like some pussies.... you could just clamp it in a band saw and start cutting, if you feel good you could clamp in a vice and take a sawzall to it then have the machine shop mill it smooth again... you could cut it with one of those metal cutting chop saws, if you dont have one they are cheap at harbor freight Quote Link to comment
budsaipan Posted October 29, 2010 Author Report Share Posted October 29, 2010 Alright, you guys convinced me. I'll give it a try again. Do you think the intake from the 240z will work? Oh yeah, the same local machine shop said they can't even mill it smooth for me on the first one I cut! Quote Link to comment
