1973 620, L16, 4spd, clean black interior
1973 620 pickup
Mostly canary yellow, and grey primer
Body has some damage, and has some rust
AWESOME black interior. Cracked dash of course, clean black door panels, cleanish black vinyl Fiat seats (some tears)
L16, Weber, 4spd, Hooker header! And a bent and blown out muffler
Runs awesome when it's warm, could use some carb work
Diamond racing style wheels in good shape, with like-new 205/60/15s on them
Slightly lowered
Electronic distributor (no more points!)
Seatbelts out of a 77 pickup to eliminate the factory two piece ones
Brand new brake master cylinder, front shoes, front drums, new hardware, new wheel cylinders, and new driver's side front adjuster. Rear brakes probably need to be adjusted, but it stops pretty good!
Comes with two spare transmissions, and a bunch of other crap
I want $700 for it, will entertain all offers. Will sell for less if you bring your own wheels and tires.
  • Replies 16
Nope! Front driver's adjuster kept collapsing under the pressure of the wheel cylinder, causing the wheel cylinder to overextend. New adjuster and wheel cylinder and she's all good now, but the rear brakes could use adjusting.
Really need the money now, someone come get this thing!
alt, regulator, starter....... all at once. nice huh??? and now the passat wont even start and i gotg a new maf and trans mount PLUS a steal of a neuspeed upper strut bar. all pretty much worthless if it wont start. i think the coilpack died.
  • 3 months later...
  • 1 year later...
