195sRFast Posted October 17, 2010 Report Share Posted October 17, 2010 Will a l16 head will work on a l20b block. Just got my l16 head back from the shop but the new rings for the l16 block are too small. I have a l20b block that has been redone and am wondering if they will work together? Quote Link to comment
datzenmike Posted October 17, 2010 Report Share Posted October 17, 2010 Yes it will. I swapped an L20B from a car into my 521 back in the late '70. My friend who had it blew the gasket and I helped fix it. So I got it off him and within a month It blew again, I replaced it and it blew again. My first warped head, duh. While it was being shaved I needed my truck. I went to Midway Datsun in town and they said it wouldn't fit/work.... but after checking the gasket and holes, I yanked the 210 head of my old '68 510 in the field and slapped it on. It ran fine as is didn't change a thing. Took it to the dealer and showed the guy, he shook his head and called the mechanic out to look. Guess they didn't know. What I didn't know then was the compression would be slightly higher (9.3) but maybe the gas was better back then????Yours may ping a bit. Turn the timing back slightly and keep an eye out for an L20B head replacement. Quote Link to comment
