primo74620 Posted October 7, 2010 Report Share Posted October 7, 2010 I have a 74' 620 and as I went to test the wipers, they were very slow. Are these wiper motors multiple speeds and if so what do I need to do to correct the problem? Quote Link to comment
izzo Posted October 7, 2010 Report Share Posted October 7, 2010 I have a 74' 620 and as I went to test the wipers, they were very slow. Are these wiper motors multiple speeds and if so what do I need to do to correct the problem? Yes, 74 has high and low speed (or should) the diodes inside are probably burned up. my 1980 720 had a normal slow speed, but fast was super slow. I replaced the motor and it works great now. Quote Link to comment
ggzilla Posted October 7, 2010 Report Share Posted October 7, 2010 diodes? They have two speeds: Slow and Slower. * Make sure you are getting full voltage at the connectors * Lubricating the external linkage often helps a little * Not normally needed, but lubricating the gears sometime helps Grease the linkage Check gears Check Brush Length Datsun Wiper Motor Repair Quote Link to comment
Creepy Cruiser Posted October 7, 2010 Report Share Posted October 7, 2010 The ones on my dime were super slow (to the point where they would actually stop in the middle sometimes, lol). I though it was the motor also, (because it's faily common), so I changed it out and no change. So I removed all the linkage inside of the cowl, and found one of the spindles was all but seized up solid. I cleaned everything up, lubed it real good, put it all back together, and it works better now than it did 25 years ago. (just another thing to look at) Quote Link to comment
paradoxx Posted October 7, 2010 Report Share Posted October 7, 2010 No diodes inside because is not an alternator..........nice write up gg.........gotta check mines, just in time when rain is gone here haha Quote Link to comment
