napz 2.4 swap to 620 help
bustedknuckles
  • Replies 5
I've done this with a 720 and tranny into a 620. Physically it 'drops in'.
NOTE:
The D-21 has a Z24i which is a TBI fuel injection motor. So, you can try and swap all the EFI wiring/ sensors/ ECU and high pressure fuel pump and tank. OR find a Z24 intake and carb and low pressure fuel pump for this motor from a 720.
The D-21 has a longer transmission than the 620 so the drive shaft will need shortening to match. It's only a couple of inches or less.
The Z24 has the intake on the pass side so you will need the throttle longer cable.
You will also need the Z24 engine brackets that bolt between the block and the rubber motor mounts.
