frodo70444 Posted October 1, 2010 Report Share Posted October 1, 2010 to put new shoes on the back of my 210 do i need to buy the hardware kit? and whats the best factory replacement brand for the brakes all the way around? im fairly agressive when i drive any advice would be appreciated ive seen one set of brembo rotors couldnt find calipers and ive seen alot of centric rotors callipers pads etc. im not abig fan of missmatching name brands ya know Quote Link to comment
hang_510 Posted October 1, 2010 Report Share Posted October 1, 2010 do i need to buy the hardware kit? no, but dont get caught stealing either!!! its never a bad idea to do so... if everything looks OK, you should be fine. Quote Link to comment
frodo70444 Posted October 1, 2010 Author Report Share Posted October 1, 2010 no, but dont get caught stealing either!!! its never a bad idea to do so... if everything looks OK, you should be fine. kool what about centric pads and rotors will they hold up? Quote Link to comment
nismo dr Posted October 1, 2010 Report Share Posted October 1, 2010 centric is your jobber parts for the masses... its what goes on every car at the midas, meineke, etc around here at least. don't seem any worse then your average aftermarket replacement parts - better than duralast but i could wittle shit better than that junk Quote Link to comment
frodo70444 Posted October 1, 2010 Author Report Share Posted October 1, 2010 yea i shold just go mine sum precious metal and sum coal build a forge and cast my own brake pads huh lol where could i get sum nice pads what company? maybe brembo pads or sumtin i saw brembo factory replacement rotors on the site but only centric pads Quote Link to comment
datzenmike Posted October 2, 2010 Report Share Posted October 2, 2010 Because the rears only do < 20% of the breaking I don't think it matters much what you use. As a rule after market shoes barely meet the OEM requirements of the factory part. The Nissan pt # is 41060 U6728 for the replacement pads. Around $40 or so. If you haven't replaced the brake fluid in the last 3 years, now's the time. Quote Link to comment
ggzilla Posted October 2, 2010 Report Share Posted October 2, 2010 To summarize: almost never is a rear drum brake hardware kit needed Also, Nissan makes the best brake shoes, but you won't notice the difference. Many aftermarket ones last longer, but the Nissan ones have the certain combintation of wear/performance/noise as per original. The Brembo rotors are nothing special, certainly not any better than the Nissan rotors. Mix-and-match away, that's what us Ratsun guys do. Quote Link to comment
frodo70444 Posted October 2, 2010 Author Report Share Posted October 2, 2010 Because the rears only do < 20% of the breaking I don't think it matters much what you use. As a rule after market shoes barely meet the OEM requirements of the factory part. The Nissan pt # is 41060 U6728 for the replacement pads. Around $40 or so. If you haven't replaced the brake fluid in the last 3 years, now's the time. 20% huh? im aggressive i need all the brakes i can get within reason im trying to avoid emergency downshifting Quote Link to comment
datzenmike Posted October 2, 2010 Report Share Posted October 2, 2010 Braking, forces a transfer of weight to the front wheels which increases traction and prevents them from locking up. Unfortunately, weight is lifted off the rears which would allow them to lock up easier. To prevent this, brake systems are biased with less pressure sent to the rears. Hard breaking and sudden down shifts can easily over power the already poor rear wheel traction and cause lock ups and over steer. Quote Link to comment
