budsaipan Posted September 24, 2010 Report Share Posted September 24, 2010 So I bought a Z22 for my lz project. I put the head on and everything and I just realized one of the timing bolt is stripped. I guess the previous owner decided to use easy out or some f***kn hard metal into it to take it out and snapped it too. I tried to drill it out with a carbide and not even a scratch. I also tried carbide dremel bit and just barley shaved some off. Then tried torching it with the propane torch I had lying around then used a punch to hammer it since it's suppose to be brittle. No luck. I messed up my punches. Now I was wondering if I can just run it without the one bolt and maybe use permatex or something to seal it up. This bolt is on the left side, second to the top of the l20b timing cover(looking at engine from front). It's the one right below the first bolt on the left top side of the timing cover. Quote Link to comment
datzenmike Posted September 24, 2010 Report Share Posted September 24, 2010 Run with it. Quote Link to comment
budsaipan Posted September 24, 2010 Author Report Share Posted September 24, 2010 So any idea how I can take this thing out?? I ran out of ideas... Quote Link to comment
ggzilla Posted September 24, 2010 Report Share Posted September 24, 2010 I wouldn't bother. The bolt near the top is not critical. The oil is not under pressure so it probably will not leak. Quote Link to comment
budsaipan Posted September 25, 2010 Author Report Share Posted September 25, 2010 I'll try it out and well if it leaks, I'll just pull it out.. Thanks. Quote Link to comment
hogboy52 Posted September 25, 2010 Report Share Posted September 25, 2010 The ultimate stuck fastener fix is the oxy torch. A stuck bolt when heated to a dull red and then cooled will be hardly more than finger tight. In this case I would use a 00 tip and heat the broken extracter bit to a bright red. This should un-harden it enough to drill or grind out. The bolt itself by this time would have shrunk enough to spin out easily with an extracter. Quote Link to comment
budsaipan Posted September 26, 2010 Author Report Share Posted September 26, 2010 Yeah I wish I had an oxy torch to try this out. Actually I could bring it to my friends shop to have it torched out but having to transport the engine is a big hassel. Thanks for the tip. Quote Link to comment
