Brian D Posted September 16, 2010 Report Share Posted September 16, 2010 I am going to order some wheels in the next couple of days and I was wondering what tire size you guys are running. I have a 67 520 and I am re-indexing the front and blocks in the rear to level it out. The wheels will be 15x6 Quote Link to comment
Zeusimo Posted September 16, 2010 Report Share Posted September 16, 2010 I Have P205/70SR14 BFGoodrich Radials In Front And P225/60R14 BFGoodrich Radials In The Rear Quote Link to comment
INDY510 Posted September 16, 2010 Report Share Posted September 16, 2010 I have 205/60/13 tires in the.............. oh wait,, what does that have to do with a 15x6 wheel? How low do you want the truck??? ..... I'd say your looking for anwhere between a 185/50/15---185/60/15 ..... or 195/55/15 It's hard to pick a tire for you without more info.......... do you want lower profile tires?.... ..wide whites?. . .. mad strech? Quote Link to comment
Brian D Posted September 16, 2010 Author Report Share Posted September 16, 2010 i am going to drop it 4 front 4 rear. I would like to find some whitewalls. if not just lower profile Quote Link to comment
banzai510(hainz) Posted September 18, 2010 Report Share Posted September 18, 2010 lower it 1st then see what tire fills up the wheel well. I have 205 /65 15s just to help it look lower as I got 3in blocks. Lowering a truck more than that starts to get in pinion angle changes(carrier bearing wear and noises) and if you remove leafs a,axle wrap. Quote Link to comment
