Brian D Posted September 10, 2010 Report Share Posted September 10, 2010 So today I got my fuel pump so i could finally get my 520 running. So i fired it up and got it running some what smooth shut it off and under the front of the engine I had a puddle of what looks like oil. It is coming from area of where the water pump is. I am newer to engines but not too cars. Can somebody please help me. Quote Link to comment
izzo Posted September 10, 2010 Report Share Posted September 10, 2010 double check your oil pump bolts, along with the bolts in the timing cover. if it gets loose, it can and will leak out oil. Quote Link to comment
Brian D Posted September 10, 2010 Author Report Share Posted September 10, 2010 sorry bottom of water pump top of timing chain cover Quote Link to comment
Brian D Posted September 10, 2010 Author Report Share Posted September 10, 2010 Will do thank you. Quote Link to comment
I'm BLUE Posted September 10, 2010 Report Share Posted September 10, 2010 sorry bottom of water pump top of timing chain cover Water Pumps have a design so that if the seals go bad ,,, the anti-freeze will weap out of a hole drilled ( usually ) located on the underside of the water pump itself ( if it leaks at all replace it , if it is the water pump gasket to the timing cover you can re-seal it ) ,,, another thing to do is pull up and down/side to side on the water pump to feel for "bearing play/slop" in the water pump bearing ,,, if there is any or much ---> replace water pump ... ( usually they are pretty tight from new/remanufactured ! ) Tighten all Radiator hoses , water connections , any thing else that has a hose on it ,,, wipe off or carefully spray/power wash suspected area ( for ease of inspection only/clean work area , tape off all electrical , and anything else that could be ruined by water like the distributor ) Check your front main seal ( behind on the crank pulley in the timing cover ,,, see how wet the area is and how much MIGHT/COULD be leaking out of it ! ) What torque did you apply to your fuel pump bolts/nuts ? What is the consistency of the puddle you found ??? Water , Oil , or Gas ? :D ( ^^^ I'm aware you said "what looks like oil" , but need to know what it is or isn't before we can help you ) Quote Link to comment
Brian D Posted September 10, 2010 Author Report Share Posted September 10, 2010 ok crawled under while running. it seemed to be coming from the center of the timing chain cover where the pulley ise Quote Link to comment
Brian D Posted September 10, 2010 Author Report Share Posted September 10, 2010 It si oil. there seems to be no anti freeze, by that I mean it has no green in it and seems to be the same thickness as oil Quote Link to comment
I'm BLUE Posted September 10, 2010 Report Share Posted September 10, 2010 It si oil. there seems to be no anti freeze, by that I mean it has no green in it and seems to be the same thickness as oil More likely than not , your "Front Timing Cover Seal" , but still could partially be the front of the oil pan/timing cover gasket * at the rate you talked about it is typically the Timing cover seal" ! either way you will be able to tell very quickly on your day off / time off once you remove the crank pulley bolt with impact gun or breaker bar ,,,, then use a 3/4 jaw puller to pull off Crank Pulley ( evenly usually a tight fit ) ,,, after this you will be able to tell what was leaking for sure , and what needs to be replaced ! ) h2theizzo gave some good advice ^^^ ,,, your oil pump could be leaking or just the bolts loose causing it to leak ! NOTE: Whatever you do ,,, make sure all sealing surfaces are very clean , and gaskets are un-contaminated ( as best you can ) when installing ! Put a little bit of engine oil on "Front Timing Cover Seal" before re-installing or it will burn up the seal ! ( some use grease , but I have heard grease retains heat , and will wear out the engine seal pre-maturely versus using a little of engine oil ) Quote Link to comment
izzo Posted September 10, 2010 Report Share Posted September 10, 2010 More likely than not , your "Front Timing Cover Seal" , but still could partially be the front of the oil pan/timing cover gasket * at the rate you talked about it is typically the Timing cover seal" ! either way you will be able to tell very quickly on your day off / time off once you remove the crank pulley bolt with impact gun or breaker bar ,,,, then use a 3/4 jaw puller to pull off Crank Pulley ( evenly usually a tight fit ) ,,, after this you will be able to tell what was leaking for sure , and what needs to be replaced ! ) Oh yeah, could be a front main seal, forgot about that one :D Quote Link to comment
Brian D Posted September 10, 2010 Author Report Share Posted September 10, 2010 I will do that tomorrow night after work. Quote Link to comment
