justin 620 Posted January 12, 2011 Report Share Posted January 12, 2011 Taking one out makes it really soft, to the point where any bump in the road will cause your rear-end to slam into the bumps, or your frame. It also causes handling to drop dramatically, which is never fun. IF you can find 720 leafs, get them, and use those instead. They drop the truck, while making the back more firm. And just as Banzai510 said, when you get past 3 inch you should deffinently move the carrier bearing, not too sure if you could just use some spacers and longer bolts, but I don;t see why that'd be a problem. Quote Link to comment
GOLSETH Posted January 13, 2011 Report Share Posted January 13, 2011 thanks for the info! Quote Link to comment
