Mini-L320 Posted August 7, 2010 Report Share Posted August 7, 2010 From the Radiator Fan back= I thought it was 1-3-4-2. ??? How should it be on the Distributor Cap. Quote Link to comment
datzenmike Posted August 7, 2010 Report Share Posted August 7, 2010 All Nissan 4 cyl are 1342. Quote Link to comment
Mini-L320 Posted August 7, 2010 Author Report Share Posted August 7, 2010 All Nissan 4 cyl are 1342. WHy does a 1981 210 have 1-2-3-4 for firing order. Thats how my brothers has his. and has it like this on the distributor cap. .4 .3 . .2 .1 Quote Link to comment
datzenmike Posted August 7, 2010 Report Share Posted August 7, 2010 Ha ha ha ha Read that counter clockwise. Its 1342. This is the direction the rotor turns. Quote Link to comment
Mini-L320 Posted August 7, 2010 Author Report Share Posted August 7, 2010 :confused: ?? from the back of motor to front he has his like this. back 4-3-2-1 front How is it 1342 :confused: Quote Link to comment
datzenmike Posted August 7, 2010 Report Share Posted August 7, 2010 4 3 2 1 This is on the distributor cap? Under the cap the rotor starts at the number one and turns counter clockwise to 3 then 4 then 2 and back to 1. RAD 1 2 3 4 WINDSHIELD Set the motor to TDC on the firing stroke and lift the cap off. The rotor should be below the #1 spark plug wire. Going counter clockwise the next wire is 3 then 4 then 2 and back to one. Quote Link to comment
Mini-L320 Posted August 7, 2010 Author Report Share Posted August 7, 2010 On the Datsun Manual Book it says, to put the rotor facing Opposite from #1 Now Im really Confused :confused: :confused: :confused: Cause I cant tell if my Timing is way off or my ZX11 Carbs are Way off. Quote Link to comment
Mini-L320 Posted August 7, 2010 Author Report Share Posted August 7, 2010 It cranks over and tries to start but it back fires from the carbs. I see flames coming out??? Quote Link to comment
datzenmike Posted August 7, 2010 Report Share Posted August 7, 2010 On the Datsun Manual Book it says, to put the rotor facing Opposite from #1 Now Im really Confused :confused: :confused: :confused: Cause I cant tell if my Timing is way off or my ZX11 Carbs are Way off. They mean next to the #1 trust me. If the plug wires are not in the 1342 order you will get flames. Quote Link to comment
Mini-L320 Posted August 7, 2010 Author Report Share Posted August 7, 2010 I will try that Tommorrow then. If this doesnt work then Im just gonna get rid of the CVK's and put the Stock carb back in it. I wonder how much I can get for the ZX Carb setup. :rolleyes: Quote Link to comment
ggzilla Posted August 7, 2010 Report Share Posted August 7, 2010 Almost all inline 4s are 1-3-4-2 -- and certainly all Datsun ones. Here's an A15 distributor Quote Link to comment
